Help with MLA and MTA versus ibrd and ibwrt
I have an instrument that appear extremely cranky with GPIB communications,
more specifically locking up very easily and doesn't allow multiple reads.
Now, I am not a GPIB vizard, so I have not been able to find a satisfactory
solution and hope for some help for the process.
Short version of my problem: ibwrt() and ibrd() doesn't work satisfactory,
MLA, MTA combos do. How to get the same performance with high-level GPIB
commands?
I am using a NI AT-GPIB board under WIndows 95, and eventually want to write
a control program using LabWindows/CVI. For now, I am trying things out
using IBIC and checking things with NISpy. The instrument is a resistance
bridge, measuring on a platinum resistance termometer (Tinsley Consort
5840D)
Problem: I initialize the instrument with ibdev(0,8,0,11,1,2060), ie.
primary address 8, a short timeout, EOT on, and requesting EOI be set when
writing the EOS character 0x0D (just to be sure). I can then read the
current value using ibrd, which is terminated correctly and all that, or
write a command using ibwrt terminated by the end-of-command character 0x0D
("\r") followed by a read. Observation: When writing a command, the bridge
balance is upset, and it takes some 20 s for the reading to stabilize again.
After reading, I see that the END bit is set in ibsta. IF I do another read,
the instrument will lock up. If I wait for RSQ (ibwait(0x4800) nothing
happens (also if I increase the timeout), if I do a serial poll ibrsp
nothing happens, if I try to trigger the instrument with ibtrg it lock up.
Observation: The END bit is still set in ibsta whatever command I use. Only
by writing an empty command ibwrt("\r") will allow me to read a new value
(and clear the END bit). I simply cannot find a way to read subsequent
values without writing a command to the instrument with the balance upset
and a long waiting time for stabilisation, as a result.
Alternative, that works: After contact to the company, which had no
solution, but sent me a couple of lines of working code, I found that the
old HP-Basic (or HT-Basic as you can find nowadays, also for Windows) can in
fact read the darned instrument without having to write commands to the
thing. HT-Basic uses commands like ENTER , 708 to read an instrument at
GPIB 8. So with the help of NISpy I looked what was going on, and the
following happens:
The instrument is on GPIB address 8. Initially, the board is set up with PAD
21, TMO 1s, no EOT. The interface is cleared(?) with ibsic, the REN is set
with ibsre(1) and the controller is set on standby(?) with ibgts(0). Then
comes the reading sequences; they are performed thus: ibcmd("H?5"), which I
interpret as MTA21, UNL, MLA8, ie. I talk on 21, unlisten, I listen on 8.
Then follows a sequence of single byte reads, ibrd, until SRQI and some
other bits are set in ibsta (ibsta changes from 0x1164 to 0x3164) and the
read is complete. The next read sequence can start immediately after with
the ibcmd and the ibrd's etc.
My question: How can I (Can I?) reproduce this behavior with high level
commands, without having to resort to direct board-device level
communication? Any help appreciated.
Hans D. Jensen
(4,468 Views)
OK I found it. Use 488.2 commands: SendIFC(0) to initialize the board, use
Receive() and Send() to talk to the device directly. How simple can it be...
when you figure it out.
"Hans D. Jensen" wrote in message
news:3a5471e6@newsgroups.ni.com...
communications,
satisfactory
> commands?
write
> 5840D)
0x0D
again.
read,
Only
in
at
> following happens:
PAD
I
> Hans D. Jensen
(4,468 Views)
