Hey Nokuy,
Something that you may try, is go to Device Manager, by right click on My Computer->Properties->Hardware Tab->Device Manager. Check that the board is associated with National Instruments. Something I would recommend is right click on the board, and click uninstall. Uninstall will really just un-associate the board with the driver it is currently using, and will re-associate it with the correct driver. Then restart the computer, and it should go through the new hardware wizard, and you should be able to see GPIB0 in MAX.
If not, just let us know.
Nick D.
