GPIB with Excel 64-bit and VBA
how can I use GPIB (using GPIB-USB-HS) with Excel 64-bit and VBA? What must be installed, which settings must be used, etc.? Is there some kind of step by step howto?
Looking forward to hearing from you. Many thanks in advance.
Best regards, Jens
(4,472 Views)
Accepted by Jens2
I recommend using VISA.
VISA can easily support connections using interfaces other than GPIB.
See my post in the thread below for more information.(Please refer to the post below after installing NI-488.2 and NI-VISA.)
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Updating-GPIB-from-Windows-7-to-Windows-11/m...
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Find-all-Instruments-on-GPIB-using-VBA/m-p/4...
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/VBA-USB-control-example/m-p/4332873
(4,437 Views)
It works, I am so happy. Thank you very much!
(4,417 Views)
