GPIB write keeps returning error 3
Hi.
I'm using GPIB card to connect my PC(LabView) and HP3458A. HP3458A is also connected to Fluke calibrator as a function source.
I'm just trying to initialize GPIB, then write to it, and read it.
I succeeded once.
Then I'm getting error out after writing.
I see that it meens wrong addressing. HP3458A is initialized to 23 and I'm using this address to write and read.
Can someone tell me what I'm doing wrong.
Kristina.
(5,157 Views)
Hey Christyine,
I have found the following KnowledgeBase titled GPIB Error Codes and Common Solutions , that I would like for you to take a look at, specifically the part on EADR (3). Please let me know if this proves to be of help.
Thanks again and have a great day!
Nicholas K
(5,123 Views)
Thank You.
I have another thread...
I hope You have answer too. 🙂
(5,064 Views)
Hello. I have this situation: With GPIB Read we can read 2, 4, 8, 16 bytes what is OK. But I have one category (MSIZE? from Hp3458A) which gives as answer: ASCII - 16 bytes per reading1 SINT - 2 bytes per reading DINT - 4 bytes per reading SREAL - 4 bytes per reading DREAL - 8 bytes per reading It can be seen 2 equal number of bytes for DINT and SREAL. So, I should write string as input to GPIB Read. Is this possible? I have .vi in attach.
(5,062 Views)
Your program makes no sense. If the instrument is returning those values, just do a read and you will get those strings back. There is no need to try and convert a string to number to determine how many bytes to read. I believe the returned values is used to determine how to interpret data returned by a measurement.
(5,049 Views)
