Why rs232 always timeout
Now i am using newport motorized stages (smc100pp).And i encounter a problem that the software always tells me rs232 is timeout with labview even though i have set the port configuration according to the company's instruction. What is the problem?
(3,324 Views)
You get a timeout when you want read characters from the port, but your device isn't sending anymore.
Or you have choosen hardware protocol, but your cable doesn't support it, or ...
Some code might help 😉
Greetings from Germany
Henrik
LV since v3.1
(3,312 Views)
