Get Status String GPIB amp manual VAGUE
I'll attach it tomorrow. I don't feel comfortable posting the VB code for certain reasons I'm not going to mention here, but hopefully the capture will help
Message 11 of 17
(1,657 Views)
here ya go
Message 12 of 17
(1,639 Views)
That has no errors. Does that mean the problem is gone or you did not run the LabVIEW code?
Message 13 of 17
(1,635 Views)
Blah, my bad. I got only the one with the VB code executing correctly. Do you need what labview was trying to send also? LabVIEW is still not executing correctly. I was in a time crunch and didn't get a chance to run the LabVIEW code with NI spy today and figured it wouldn't be a big deal since that simple screenshot I posted was so basic. If you need the labview side of things, I can get it but probably not until later this afternoon.
Message Edited by for(imstuck) on 01-26-2010 12:45 PM
Message 14 of 17
(1,630 Views)
Since you are trying to get LabVIEW to run, yes it would be nice to see what NI-Spy has to report about that.
Message 15 of 17
(1,627 Views)
Alright, thanks. Hang tight and I will get that report in a couple of hours.
Message 16 of 17
(1,624 Views)
No idea what the problem was, but it seems to be fixed. I'd put a solution if I knew what changed. Thanks for you help again.
Message 17 of 17
(1,615 Views)
