Granville-Phillips 358 Micro-Ion Gauge Controller
I need to use LabVIEW to control a Granville-Phillips 358 Micro-Ion Gauge Controller via RS-232. Has anyone already done this?
(5,854 Views)
Mosey,
I couldn't find a LabVIEW instrument driver, so it looks like you will want to program the controller using NI-VISA. The manual for this instrument is really good, I have attached it to my post. Chapter 2 has the supported serial settings and Chapter 5 has the serial commands. Make certain that you are using a carriage return and a line feed as the terminator for each ASCII string you send the device.
Depending on your LabVIEW and VISA experience, I would recommend starting out programming this instrument using one of the serial examples such as Basic Serial Read & Write which can be accessed from Help»Example Finder.  I have also posted some links that might be helpful for someone new to VISA.
NI-VISA Overview
NI-VISA Programmer's Reference Manual
Hope this helps.
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(5,842 Views)
Ben, Thanks for your help. I'll take a look at the links you provided.
(5,838 Views)
Hi
I made some vi's for a  series 370 stabil-ion
maybe a starting point
these are in LV7.1 and I'm going to use them again next month.
(5,827 Views)
