HOW TO READ SERIAL DATA WITH SYNCHRONIZATION
Another note to my first answer: You should include some boundary conditions to the shiftregister. If, due to a different setup, no match is found your shiftregister string will grow and grow.
Check the lengh and when it's longer than two times the 'match', quit with an error or warning..
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 13
(1,458 Views)
Accepted by topic author SERDARSOYLU
And I zoomed your image and saw that your indicator is a U8. That explains why you are not seeing the correct value.
Message 12 of 13
(1,446 Views)
Thank you so much all. Now the code is working great. I'll certainly implement some sort of an error loop to make sure the the shift register does not grow in size.
Best Regards
Serdar
Message 13 of 13
(1,429 Views)
