HOW to use simulated device to createPCI-8431 or COMports SERIAL simulating manner.
HI
Virtual simulating port COM or cards for cards as NI PCI-8431, PCI-232,... (NI cards to use),  in softwares as MAX (Measurement automations ) or (Labwindows-CVI),
Object is only simulating while there's no physical cards to install.
Thanks for help.
(3,338 Views)
There is nothing built into MAX or VISA to simulate a com port but there are numerous products available that can d it. Try using google to search for 'virtual com port software'.
(3,336 Views)
The problem with simulation is the expected reaction from the other side.
The best you can do is to write a vi that sends and recieves data and that also simulates if a comport of "none" is selected.
greetings from the Netherlands
(3,323 Views)
