HP 4194A via GPIB?
Connecting to a HP 4194A via GPIB and upon scanning for instruments the device does not respond to the *IDN? query?
Message 1 of 8
(6,251 Views)
This is common with old instruments, like the 4194A. Older instruments did not implement the standard set of SCPI commands. Most likely it has an "ID" command, or something similar.
If you haven't already done so you should download the driver.
Message 2 of 8
(6,250 Views)
I tried "ID" and several versions thereafter between that and "*IDN?" and still no repsonse.  Yes, I downloaded the drivers.  Any other idea?
Message 3 of 8
(6,228 Views)
Did you try to read the manual before sending random commands or look at the initialize function's block diagram? There is no id query for the instrument.
What function did you try in the driver? What error code did you get?
Message 4 of 8
(6,226 Views)
Get back to you Monday after I've had a chance to get back to it.
Message 5 of 8
(6,211 Views)
Jimbo,
I had tried the command ID? and this worked for me.
Davidson
Message 6 of 8
(5,979 Views)
Please I need your help connecting my HP4194 A with the computer.
IT always says "IDN string not available".
Any advice please? I am really lost.
Thanks for everything.
Karim
Message 7 of 8
(4,333 Views)
Try the following:
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/What-is-the-Scan-for-Instruments-sequence-fo...
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 8 of 8
(4,319 Views)
