HP 6034L power supply
Does anyone have a driver or a command list for the HP 6034L power supply?
Message 1 of 8
(6,833 Views)
Hi, have you tried using the HP 6034A or HP 6034B drivers with your power supply. I would assume that Agilent uses the same command set for this family of instruments (they usually do). Here are the links for agilent's power supply drivers (IVI, LabView and VXIP&P):
http://sine.ni.com/apps/we/niid_web_display.drv_results?p_app_area=&p_man=agilent&p_keywords=&p_inst_type=powerSupply&p_env=&p_drv_type=&p_int=
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=196&SESSION_ID=499-1100587735-7654757
"Only a life lived in the service to others is worth living..." - Albert Einstein
Message 2 of 8
(6,833 Views)
Well... actually there is no 6034A power supply. There is a 6035A and a 6634A. I did try the 6035A single output driver, it did not work. I was hoping for someone out there to have a manual or a copy of the original driver. I would be willing to pay someone for a copy of their manual. Thanks for answering.
Message 3 of 8
(6,833 Views)
OK, stop the presses!
I found someone with a copy of the manual who was willing to send me a copy. For all of you who may be needing this information as well here is an attached doc file with a biief description of the GPIB command syntax for this device. Many thanks to all.
Message 4 of 8
(6,833 Views)
Is it possible that you could send me a copy of this manual. We have searched high and low for one.
email is: sales@testequip.com
Message 5 of 8
(4,999 Views)
Or you could just download the file from the above post...
Message 6 of 8
(4,994 Views)
Actually, the attached document on the 6034L is only one page long.
Message 7 of 8
(4,983 Views)
I was just wondering if anyone had ever found a driver or mannual for the HP 6034L?
Message 8 of 8
(4,895 Views)
