HP 6038A constant current
I went to that exact page, and step 1 gave me trouble.  When I go into Measurement & Automation Explorer, the only option I have on the left is Software.  Nor can I find it in my start menu.
Message 11 of 14
(1,664 Views)
ahamel,
Be sure you have the latest version of NI-VISA installed. Also, do you see your GPIB device in MAX? If not, you should follow these steps.
You can confrim which version is installed under the Software section in MAX. If you are still having trouble after installing the file from the link above, then take a screenshot of your MAX window with all the items in the left window expanded. This will help illustrate what you have going on in your system.
Peter Flores
Message 12 of 14
(1,639 Views)
I believe that I found my problem.  I wasn't setting up a current for the power supply, and it defaulted to 0.  Since I've changed it, I haven't encountered the problem.
Message 13 of 14
(1,632 Views)
Great news, thanks for posting your solution!
Peter Flores
Message 14 of 14
(1,619 Views)
