HP4192A step by step sweep
Dear all,
based on standard NI driver I 'm trying to organize several measurements with HP4192A in Labeled 8.0:
- bias scan at a constant predetermined frequency and the oscillator level (CV measurement);
- bias scan at f = 0 Hz (IV measurement);
- frequency sweep at constant bias and the oscillator level (Z(f) measurement);
In the standard driver the measurements are running in the "auto sweep" mode without setting the frequency in "bias sweep" or bias and oscillator level in the "frequency sweep".
But I need to control these parameters and get the values step by step in the sweep, because I want to display and calculate the current values locally. As I'm trying "W1" command my VI do not works.
I'm wondering, if I need to use the "auto sweep" with "pause" command by reading or multi run the "W0" with floating window (Start+n; Step; Stop+2n) or something correct in my "manual sweep" command line?
It would be grateful to get you advice!
(4,066 Views)
I've got it.
So long, and thanks for all the fish!(c)
(4,046 Views)
