Sorensen XG series AUX output LabView Control
I have control of the main output supply using the XG Series LabView VI's (DC850W).  I would like the capability of enabling the AUX output via LabView control.  I set the AUX output via the front panel to be on at power up, however when I run the DC850W example program the AUX output gets disabled.
(4,317 Views)
which LabVIEW VIs are you using? Were they part of a driver you downloaded? I've looked on our instrument drivers network and it seems the only driver available for that is the LabWindows/CVI drivers. If you could provide the VIs you are using or the location where we can find them, that would be very helpful in looking at this issue.
Gabriel M.
Product Marketing Engineer - Academic Courseware
(4,288 Views)
I downloaded the DC850W IVI LabView Driver from this page: http://www.sorensen.com/products/XTR/XTR_Downloads.htm.  The file is this: http://www.sorensen.com/products/XTR/downloads/XTR_XG_LabVIEW_v1001.zip
(4,183 Views)
The programming maual is here:  http://www.sorensen.com/products/XTR/downloads/XG%201700_1500_850%20User%20Manual%20M370430-01%20Rev....  On page 3-17 it describes how to Enable the Auxiliary Output, however there is no LabView Adapter for "
[:]OUTPut[<channel>]:AUXiliary[:STATe]" .  This there a way to make that into LabView?
(4,180 Views)
If there is a function missing in the driver, just write your own VI and add it.
(4,172 Views)
