HP6198 Switch/Load unit with labview
I'm trying to control an HP6198 switch load unit with labview. It uses a parallel interface and an old active X driver (Which I have), but I'm having difficulty getting the driver to access the port. I have set it up for ECP mode. Has anyone ever tried to use this with labview before?
Greg
(3,760 Views)
Hi Greg,
We have a very good tutorial on how to set up Parallel communication in LabVIEW that you might find useful.  Let me know if you have any questions!
Chris R,
Chris R.
(3,743 Views)
Wow, I should have known this, it is really a nice doc. Especially now the lv8 stuff supports port access again, thanks
greetings from the Netherlands
(3,736 Views)
Thanks for the replies! I did get it working. Agilent no longer supports the device, and the documentation is sparce, so we had little information. But after finding a later version of the active x driver I got it to work. So if anyone ever needs to control this unit, I have had success with it!
Greg
(3,710 Views)
