HP6633A to HP6633B conversion (Driver Needed)
We have sevral test stations running LabVIEW 2011 that contain a HP6633A power supply.  Recently, we have not been able to get HP6633A from our vendor so someone purchased the HP6633B instead, thinking it would be a drop in replacement.  Turns out, it's not, the VISA command set is totally different.  I'm posting this on the off-chance that someone has developed a driver that can talk to both, or at least a driver for the HP6633B that is LabVIEW 2011 complient.  The only driver I could find for the "B" model was for LV2012 and up.  I understand I should talk to Keysight, and I am doing that in parallel with this post.  Just hoping to get lucky.  Thanks, Pat
(4,876 Views)
Accepted by topic author pd110
You should be able to switch the new power supply between old compatible and new command language using the SYST:LANG Command  ( See Appendix B of devices programming guide)
(4,854 Views)
Thank you for pointing this out, you saved me a lot of work!
(4,847 Views)
Check the LANG selection in the Power supply.  I use the 6632A and B versions.  The A versions have the COMP language while the B versions are SCPI compliant.  You can choose COMP in the B versions and they will act like an A version supply.  It is a setup within the power supply, I typically use the NIMAX to check the setting and make the change there.  It will hold this in memory even after power cycling.
Cheers!
(3,873 Views)
