Have to add a delay in Agilent 3446x labview driver
I was seeing a weird bug in the Agilent 3446x driver on the driver page.
Running initialize.vi results in a long wait (~2 minutes) followed by this error:
Error -1073807339 occurred at VISA Read in Agilent 3446X Series.lvlib:Error Query.vi->Agilent 3446X Series.lvlib:Reset.vi->Agilent 3446X Series.lvlib:Initialize.vi
Possible reason(s):
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
Then if I run the code again I get this error:
Error -1073807360 occurred at VISA Open in Agilent 3446X Series.lvlib:Initialize.vi->Ivan acquire single.vi
Possible reason(s):
VISA: (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
I narrowed it down to a read call in Error Query.vi. I was able to fix it by inserting a 1 second delay in between.
I thought I'd write this up for anyone encountering this issue in the future.
I'm testing with a keysight 34465A firmware V, Windows 10, and Labview 2017.
(5,425 Views)
Thanks for the info! I'm sure this will help people in the future.
You can also email instrument.drivers@ni.com with this write up to provide direct feedback.
(5,385 Views)
Thank you so much, finally it works Heart
This bug is still existing...
(5,153 Views)
To echo Salazaar.Slytherin above, giving feedback to instrument.drivers@ni.com directly would be helpful feedback.
(5,138 Views)
This is a sneaky bug in the driver. I was tinkering with the driver for 2 days. Thank you for the solution.
Added the delay in the error query.vi and it works perfectly
Windows 7 64bit with Labview 2017 32bits.
Now I can code!
(4,542 Views)
Delay is needed once after the reset (speed up meas)
(4,173 Views)
