NiViTulip.dll
I'm trying to use a Keysight 82357B (USB-GPIB converter) with NI MAX. With older version of NI MAX this worked proprerly. Now I'm using NI MAX 19.0 and it doesn't work.
The problem is that even if Tulip dll is installed I can't find it in NI max. Do you have any idea to solve this problem?
Thank you in advance
Best regards
Nicola
(2,470 Views)
Hi Nicola,
Previously some other users experienced similar issues, you could try to:
1) Uninstall everything NI related (LabVIEW and the drivers)
2) Disconnect your device from the computer
3) Install LabVIEW (as Admin)
4) Install VISA driver and NI 488.2 (as Admin)
5) Reconnect the device to your computer
Also consider setting Keysight Visa as a Secondary Visa installation.
Kind regards,
S.N
(2,423 Views)
