Serial data comes in with delay and in inconsistent batches
Hi everyone,
I'm having issues with getting quick, smooth data from a serial device. Data currently comes in large chunks (0-4000 bytes), interspersed by many empty reads, which results in visibly delayed acquisition of data. (Chunks come in at ~4 Hz.) I know that streaming smooth, timely data (at a very high frequency) is possible, because we have a MATLAB Simulink program that is able to achieve this with the same device (using FIFO Read Binary).
I'm currently streaming data from a device that sends packet data without termination characters. Each packet starts with [45, 62] and is then followed by seven bytes of data. The attached VI uses a consumer-producer loop. The producer handles serial communication while the consumer is a state machine that identifies headers and then processes them into usable form. I suspect the issue is with the producer loop, but I included the entire subVI for examination. It's currently written to be part of a larger program (stops are linked to a ref and all data goes into a queue).
Things I've tried include:
  1. Reading 1000 bytes, with 0 timeout. This results in the same behavior.
  2. Reading 4 or fewer bytes with 10000 timeout. This results in functionally the same behavior as above, except rather than returning empty data, it just waits for a moment before returning a "burst" of reads over many iterations of the producer loop.
  3. Using a timed loop with T=1ms, timeout=1, read 4 bytes. Very smooth data coming in, but very significant lag between device and LabVIEW read data.
  4. Using a timed loop with T=1ms, timeout=1, read 36 bytes. Same as original issue, with "chunky" data stream.
Any advice or help would appreciated. I suspect there's something I'm misunderstanding about serial ports, and could use guidance from y'all.
Thanks a bunch!
(3,430 Views)
I had same issue when i started with custom VISA communication.
I think your problem is that you use Bytes at port function, rather than using that just read a large chunk, for example 1000 bytes.
(3,399 Views)
Hi AeroSoul,
Thanks for your suggestion. Having tried that with timeouts of 0 and 10000, the behavior seems to be roughly the same, with data coming in about once every two seconds. With timeout of 0, most reads are empty; with timeout of 10000, the loop iterates ~4 times, waits about 0.5 seconds, and then reads 4 times again. It's almost as if the device itself sends data in clumps of ~4000 bytes. I only know this not to be true because I've seen it working on Simulink. (Note: the Simulink interface is on a different PC.)
I'd be open to investigating the device output with another machine/device, but am not sure how.
(3,392 Views)
Accepted by topic author charleslu
Came across the solution with some online digging. Turns out it has nothing to do with LabVIEW at all. What I needed to do was to go into the COM port device driver advanced settings in Windows Device Manager and switch latency from 16 ms (default) to 1 ms. All issues have gone away.
(3,365 Views)
Good catch
greetings from the Netherlands
(3,353 Views)
