Having Problems with Instrument I/O Assistant.
Hi
I have just installed the demo from NI of Labview. I am trying to
run
Instrument I/O Assistant. Open blank Vi then select GLIB and sure
enough
Instrument I/O Assistant dialogue is there. However, when you double
click
the box, as the help suggests, it report that Measurement and
Automation
Explorer or Instrument I/O Assistant may not be install. Do they come
with
the downloadable demo? If so what is happening?
Wayne
(3,250 Views)
Hello Wayne,
Even though the I/O Assistant VI appears in the palette it is not
actually installed. You need to install the I/O Assistant from the
Driver CD. When you sign up for the demo, the driver CD is mailed to
you.
Ray
(3,250 Views)
