I have tried three different versions of 488.2, ranging from 2.0 to the current version.. I made sure to uninstall the old version before i put a different version on.
The exact error message from the Troubleshooting Wizard is this:
One or more GPIB interfaces failed.
Double click on each individual GPIB interface, for example "GPIB0" in the list for detailed information about the status of that interface.
I only have one interface installed, and if i double click on it as the message above indicates:
It references the help file, under the section "Unknown Hardware Error". I've tried everything listed there, since this is a PCI board, there's not much in the way of potential resource conflicts.. I've also tried putting the board in a different slot.
If i have "NI Spy" capturing while i attempt to run the troubleshooting Wizard, i get the following message:
1 ibfind(GPIB0) Status 0x8000 iberr EDVR(0) ibcntrl 0xE01E005E
If i go to the interface in MAX, then click "Scan for instruments", it reports that the GPIB interface has been incorrectly configured, and to run the Troubleshooting Wizard.
Ni Spy reports the following messages when attempting to "Scan for Instruments"
the first message is identical to the one reported by the Troubleshooting Wizard.
The second has ThreadIbsta() with the same parameters as the first message.
The third has ThreadIberr() with the same parameters also.
I can capture the screen, but i don't have a place on the web to upload them to.
