Help me, Used Modbus in Touch Panel Module with Windows CE 5.0
'm using the Labview 8.6 & 2009 Touch Panel Module.
I want to use Modbus Library.
Master example is ok.
But 'MB Serial Slave Demon.vi' is error in Touch Panel Module at Windows CE5.0.
20299i880EEA80D27028D0
The red circle is error.
That doesn't support in Touch Panel Module at Windows CE 5.0
Second error is below.
20303iFC2350D2EC543CC8
in detail, The icon dosen't run.
20305i56A097ECD2971B12
How can I use the modbus library in winodws ce5.0?
(5,022 Views)
Hi WHC,
The Modbus library was written for LabVIEW Desktop, as such it contains many functions that are not supported on embedded targets such as LabVIEW Touch Panels. Your best option might be to create Modbus VIs for your own use.
If Modbus functionality is critical to your application, I would recommend the NI TPC-2515D or the NI TPC-2512D touchpanels. They are XP Embedded touchpanels and include a license for the NI LabVIEW Datalogging and Supervisory Control Module which includes modbus functionality. You can refer to the LabVIEW DSC module help, here to search for all the modbus features available in the module.
Hope this helps,
Thank you,
Jaidev Amrite
Senior Product Manager
(4,712 Views)
Morning
I am facing the same problem than you , Do you find anysolution to be able to use Modbus Demon With Touch Panel 5.0
Thanks for your help
Regards
(4,446 Views)
