NI-VISA boot problem, less than 4Gb of RAM
I successfully installed NIKAL and NI-VISA on my OpenSuse 11.4, 32bits, 4Gb of RAM.
ion@alws36:/sbin> free
             total       used       free     shared    buffers     cached
Mem:       3959524    1121816    2837708          0      30132     702232
-/+ buffers/cache:     389452    3570072
Swap:      2099196          0    2099196
But, when I would like to start Visa Configuration Utility, pb :
ion@alws36:/sbin> dmesg
[   35.209745] Disabling lock debugging due to kernel taint
[   35.318071] [nipal] More than 4GB of addressable memory detected.
[   35.318073] [nipal] This configuration is not supported.  Check the release notes for more information.
[   35.803191] bootsplash: status on console 0 changed to on
I remove 2Gb of RAM, same problem.
I swapoff :
ion@alws36:/sbin> sudo ./swapoff -a
so now:
Mem:       1880360     881764     998596          0      28712     521368
-/+ buffers/cache:     331684    1548676
Swap:            0          0          0
But the problem is still present.
I also tried by booting the system with the option :
mem=512M
Visa Configuration Utility worked, but the system does nor accept more memory with this option.
(3,376 Views)
Which version of NI-VISA and NI-KAL are you using?
On this document you will find a list of supported distribution of Linux :
What Linux Distributions Do National Instruments Drivers and Software Support?
http://digital.ni.com/public.nsf/allkb/4857A755082E9E228625778900709661?OpenDocument
Could you try again with a fully tested configuration ?
(3,356 Views)
