Hex 0xBFFF0015 Lab v. 6.1
I have this error : Hex 0xBFFF0015 when I want read the serial port of the instrument (trought an USB port on the PC).
I find the port (RS232 at 19200 baud) with "Visa find ressource" : ASRL3::INSTR
I find some solution on this forum, but the solutions are for latest version of Labview, I can't open the exemple
Thank you for your help
(3,710 Views)
I have try to puta proprity nodle for now the number of byte at the port.
I don't have any more a proble of timeout but this :
  (Hex 0x3FFF0006) Le nombre d'octets transférés est égal au décompte d'entrée.
(3,703 Views)
It's a warning. Haven't you done a search for that code? Since you are specifying the number of bytes and not getting a termination character, that warning is normal.
(3,691 Views)
I don't have termination character, and I know that I have more than only 1 octet.
I put the nodle for avoid the timeout error. I wait 2 second (about 1.5 seonds calculation of the instrument) before to check the number of octet on the port and read it.
(3,672 Views)
