Hi ALL, I need to control the temperature of a furnace. The Thermocouple ouputs are available as RS-485. What Hardware and system configuration should I prefer?
I need to automate the control of a gas carburising furnace. The available signals are Thermocouple K-Type (4 nos., one each from the three zones and one from the geometrical center of the furnace) and Oxygen Analyser. That makes it a total of 5 signals, all available in RS-485 format, which I need to acquire (10 samples/second) and then initiate a control action as per the rule base. Reliability is a major issue and the system has to work in harsh conditions.
What hardware would suit my purpose? I would prefer NI hardware which can be programmed via VB or VC++. LabVIEW may be considered as the last option.
Apart from using the thermocouple/Oxygen analyser signals for controlling it is also desired to store them on a PC for analyses and visualisation (via graphs etc etc)
My need is URGENT and would appreciate any help. Thanx in advance
Gurdas
(3,302 Views)
Hi Gurdas,
It looks like you need to connect to 5 separate signals via RS-485 in a harsh environment. Is this a correct assessment?
If so, there are several NI serial products that work well in harsh environments. The ENET-485 comes in 2 and 4 port configurations and allows you to communicate with your serial device over Ethernet. For more information about the ENET-485, please see http://sine.ni.com/apps/we/nioc.vp?cid=10631〈=US. Please note that the ENET-485 currently only works with Windows NT.
For a more robust solution, the NI PXI Serial products offer an 8-port PXI board (with isolation if needed). For more information please see http://sine.ni.com/apps/we/nioc.vp?cid=1880〈=US
Additionally, our PCI-485 board comes in 8-port versions a
nd offers isolation for noisy environments (http://sine.ni.com/apps/we/nioc.vp?cid=1846〈=US).
If you'd like to speak to one of our sales representatives or an applications engineer, please call 512-794-0100.
Matthew Smith
Serial Product Manager
(3,302 Views)
