How can I determine the physical location of PCI-GPIB controllers.
I have two PCI GPIB controllers in a system and want to insure that a controller plugged into a specific PCI slot is always named GPIB0 and the other GPIB1.  I need to do this without any human intervention - i.e. NOT using measurement and automation explorer to check which devices are plugged into the controller.  How can I accomplish this?
(4,032 Views)
The only idea is to use the serial numbers and always put them in a specific order in the slots.
In that case the card with the lowst serial number is GPIB0
greetings from the Netherlands
(4,018 Views)
Thank-you for the interesting idea.  It would be better if I could tie the serial number to a PCI slot somehow.  I don't think I can guarantee that the serial numbers will be inserted in the slots in order.
(4,010 Views)
Hi Marcateagle,
    You can use "VISA Find Resorces" to determine what devices are plugged into GPIBx.  I have attached example code.  I hope this helps.
George
(3,988 Views)
Or, try this VI to get controller information.
-George
(3,975 Views)
Thanks for the input, I should have mentioned that I need to do this using a c / c++ interface.
(3,970 Views)
How are you communicating to the devices in C?
If you have the NI-488.2 driver installed you can use the same functions as the LabVIEW code above. The functions should be in the GPIB/GBIP 488.2 library.
There is also a ibpad function that looks fairly promising. Here is an excerpt from the LabWindows help about it:
This function sets the primary GPIB address of the specified board or device.
Note: When this function is called and an error does not occur,
the previous primary address is stored in the global
error variable "iberr".
/*-------------------- Prototype ---------------------*/
int ibpad (int BoardDevice, int Primary_Address);
CLD Certified
(3,950 Views)
