gpib-usb-a
hi,
I`m trying to use a gpib-usb-a to control a hp datalogger but it just dont work.
I`m using windows XP and ni4882.22. The gpib-usb-a appears in max but when I run the troubleshoot wizard it get me an error. This error is that "address resource conflict in windows 2000/xp".
In the device manger everything seems to be ok.
Please help me.
(3,506 Views)
Probably the NI 488.2.2 driver was not correctly installed.  I suggest you try eliminating the driver from your computer by following the steps placed in this website:
https://www.ni.com/en/support/documentation/supplemental/18/uninstall-or-repair-national-instruments...
You can download the driver from the following website:
https://www.ni.com/en/support/downloads/drivers/download.ni-488-2.html
I also recommend that you check out the following information before you start using the gpib-usb interface cable.
https://www.ni.com/en/support/documentation/compatibility/17/ni-488-2-and-labview-version-compatibil...
Hope it helps!!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(3,485 Views)
Thanks for the help Anuar
It seems that my version of ni488.2 is not compatible with my labview version. I had never seen the labview and ni488.2 version compatibility table.
Thanks for the very usefull info.
(3,476 Views)
