How can I implement hardware independent software with instruments that do not belong to any of the five basic IVI instrument driver classes?
I want to know the best way to create IVI instrument drivers for two frequency counters that I want them be able to be interchangeable. Can I create a new class driver for counters that I can call from my test code? Should I use the general purpose template from the CVI Wizard? Or should I force the instrument driver to fit in one of the five basic instrument classes currently available, in order to have interchangeability?
(3,084 Views)
The specification of counters is not approve now. You can create a specific drivers. The actual status of IVI spec for counters you can find on www.ivifoundation.org web site. The description/template how write class drivers don't exist now and I'm not sure if will exist in future.
But I believe that class driver will available as soon as possible, when spec for counters will be approved.
Zdenek
(3,084 Views)
