Have you looked on the Agilent web site at www.tm.agilent.com.
If you seach for E4402B you will find a link to the product page. Follow the link for Software Patches and Drivers on that page. You should see a further link to the plug 'n' play driver. Follow that link until you find the driver link ESA VXI PnP Driver A.03.00.  This is an EXE file you download. Just follow the instruction. It has the LabVIEW interface you are looking for. Dont worry that it is making reference to VXI. Some times the you have to use the Convert CVI FP to obtain the LabVIEW driver VI.
I've recently used the E4406 drivers and that did have the required VI's.
The NI PCMCIA-GPIB doesn't required anything special other than the GPIB software that comes with the card. LabVIEW just treats i
t the same as any other GPIB card.
Hope this helps.
	Regards
Ray Farmer
