How can I open the .llb file?
Can anyone help me to open the .llb file for me please? I have attached the llb file with this post? Can anyone open it and send me back in the normal file format?
Regards
Mayuren Sivalogan
(7,439 Views)
An llb is a normal file format. In fact, it has been around as long as I have been using LabVIEW so I am totally confused by your question. File>Open.
(7,436 Views)
I'm using labview 8.0.
When I tried to open it, says "the filename or extension is too long".  What does it means? how can I open?
Mayuren
(7,428 Views)
How long is the path where you have the llb? The name of the llb is not too long but the library manager may not be able to open it if you have it saved under many and long windows paths. Place it in the root and try it.
(7,425 Views)
I could open and run both vi's in the llb so all is well with them. Try saving the llb to a folder under the root directory.
-AK2DM
(7,422 Views)
I have downloaded this file in the NI example code. I'll send the link for you. http://zone.ni.com/devzone/cda/epd/p/id/1026 Thanks for your help.
(7,404 Views)
I don't know why you gave the link to the file. You already attached it and two of us had no problems opening the llb. Did you do what both AnalogKid and I suggested?
(7,401 Views)
