How can I send an SCPI command to just one device on a GPIB bus?
Hi, I am using SCPI to talk to a Kiethly 2000 and a Yokogawa wt 1030 as part of a migration job for a customer.  I know which SCPI commands to send to get the data ":fetc?" and ":meas:val?" (plus the setup commands)  I know this because I found a config file among the files from the old system, the source files however seem to be long gone so I don`t have the whole picture.
What I need to know is how to send a command to only one of the two devices.
As for details:
I don't have the devices with me yet but I will receive them soon.
I am programming in C if that matters (I will be calling the program from our main control software).
I know the basics of SCPI ex: it is ascii sent by GPIB, the commands follow a tree structure...
Any help would be greatly appreciated as I seem to have reached a brick wall.
Thank you!
(6,137 Views)
When you use the VISA Write, you provide the resource name and the resource name includes the instrument's unique address. Have you looked at the help file?
(6,135 Views)
Hi, thanks for the response Dennis.
I should have mentioned that I am develloping in C for QNX and I'm not using VISA.
What I'm doing is a low level open() pwrite() and pread() to dev/gpib.
I'm not using any NI software, but this forum was by far the largest and most active on the GPIB subject that I was able to find.
So if anyone is knowledgeable in low level stuff, that`t the kind of help that I'm looking for.
Appreciate the help.
(6,117 Views)
This may be the most active on GPIB but it is for NI software.
(6,111 Views)
Ah yes, I was hoping someone might know somethnig about the lower level workings of GPIB.  Alas, I will continue searching for info, though I am still open to suggestion if anyone has some low level knowledge about GPIB.
On another level, visiting this forum has given me a good impresison of NI software, and I may consider using some on future projects that require this kind of interfacing.
(6,105 Views)
I thought you had to supply an address for those commands.  If not, you don't have a good library.  You might want to look up the support for the library you are using.
GCentral
(6,096 Views)
