06-18-2013 03:25 PM
Hi, I am using SCPI to talk to a Kiethly 2000 and a Yokogawa wt 1030 as part of a migration job for a customer. I know which SCPI commands to send to get the data ":fetc?" and ":meas:val?" (plus the setup commands) I know this because I found a config file among the files from the old system, the source files however seem to be long gone so I don`t have the whole picture.
What I need to know is how to send a command to only one of the two devices.
As for details:
I don't have the devices with me yet but I will receive them soon.
I am programming in C if that matters (I will be calling the program from our main control software).
I know the basics of SCPI ex: it is ascii sent by GPIB, the commands follow a tree structure...
Any help would be greatly appreciated as I seem to have reached a brick wall.
Thank you!
06-18-2013 03:48 PM
06-19-2013 06:43 AM
Hi, thanks for the response Dennis.
I should have mentioned that I am develloping in C for QNX and I'm not using VISA.
What I'm doing is a low level open() pwrite() and pread() to dev/gpib.
I'm not using any NI software, but this forum was by far the largest and most active on the GPIB subject that I was able to find.
So if anyone is knowledgeable in low level stuff, that`t the kind of help that I'm looking for.
Appreciate the help.
06-19-2013 07:11 AM
This may be the most active on GPIB but it is for NI software.
06-19-2013 07:50 AM
Ah yes, I was hoping someone might know somethnig about the lower level workings of GPIB. Alas, I will continue searching for info, though I am still open to suggestion if anyone has some low level knowledge about GPIB.
On another level, visiting this forum has given me a good impresison of NI software, and I may consider using some on future projects that require this kind of interfacing.
06-19-2013 11:00 AM
I thought you had to supply an address for those commands. If not, you don't have a good library. You might want to look up the support for the library you are using.
