How do I Create Distributible Package for application developed under SUN CVI 5.0.1
Thank you
(3,577 Views)
Hi Andrei,
Unfortunately CVI for SUN does not include a distribution kit packager for your applications. What I would suggest is to find a 3rd party packager and include the executable as well as the shared libraries that are part of the runtime engine. This list of files should be documented somewhere either in the runtime or when you installed CVI. I would first look on your machine to see if you can find that list of files. Then, just add those files to the package and you'll be set. Hope this helps!
Jeremy L.
Jeremy L.
(3,553 Views)
Thank you,
Please, provide me with more details on the CVI SUN runtime. Where is it located (by default), how to update links on the target machine, etc.
Thank you
(3,550 Views)
Hi Andrei,
I would go look in the CVI Programmer's Reference Manual on page 109 of 211, which explains how to distribute standalone executables under Solaris 2 or Solaris 1. Hope this helps!
Jeremy L.
Jeremy L.
(3,537 Views)
