How do I change *IDN? to *ID? to match HP 8591EM using Max 3.02
Thanks Dennis Knutson .. but I want to make sure again, it there problem is caused by  interface between a computer and spectrum analayzer or this problems is caused by this software has a expired period that has be set by the manufacture ..??
Message 11 of 17
(1,555 Views)
I don't know anything about the software from this company or what kind of license it has. All I can say is that the *IDN? query is not involved and that it appears the software is partially working since you get half way through a scan. That points (to me), that there is a problem with the code or instrument and not the GPIB board.
Message 12 of 17
(1,553 Views)
there is no other way for me to get my reading as shown in the picture before,whether make a new software or you have a easer way..?
Message 13 of 17
(1,546 Views)
As I said, check with the vendor. Of course, your other option is to write your own code.
Message 14 of 17
(1,525 Views)
i has chec to the vendor.but the vendor emain is not valid anymore..you said another option is to write my own code..are you have any idea to write a new code..in this case im using spectrum analayzer HP 8591 EM...can you help me..
Message 15 of 17
(1,513 Views)
Agilent handles the old HP-brand of instruments: http://www.agilent.com
Message 16 of 17
(1,481 Views)
thaks for your advice..
Message 17 of 17
(1,460 Views)
