How do I change the Base Address on a pci pnp gpib card?
I am trying to use 2 cards in a pc to run Fluke Metcal. I believe that metcal needs the base addresses of the cards to be 210 and 220 hex. How do I set this on the pci pnp cards? I can't seem to find it in any of the properties. How do you find out what the base address is curently set to?
(3,410 Views)
This is not supported with PnP PCI-GPIB cards. PCI does not have the same addressing scheme as the ISA bus. I don't know of a way to map addresses from an IO address to a PCI address.
This functionality will only be fully supported with our non-PnP AT-GPIB/TNT cards. You should see if Fluke has updated software that does not depend on these base addresses.
Craig A.
National Instruments Engineer
(3,410 Views)
