Yes, that was my first guess. It works fine with a different NI
AT-GPIB controller board, but with the GPIB-ENET all I get is an ECAP
capability error. Can this controller do listen-only?
On Mon, 17 Feb 2003 11:41:34 -0600 (CST), DiegoF  wrote:
>Hi,
>The NI-488.2 header file shows the configuration value for Listen-only
>mode.
>#define IbcLON 0x0022 /*Enter listen only mode*/
>This parameter is to be used with ibconfig with a board-level unit
>descriptor.  Any non-zero value will enable listen only mode.
>Hope this helps.
>DiegoF
>National Instruments
