How do I make GPIB-ENET listen-only? I want to emulate a printer.
How do I configure the GPIB-ENET to be listen-only?
I want to write a C program that captures printouts from my HP instruments.
I'm using Win2k.
Thanks!
(3,888 Views)
The NI-488.2 header file shows the configuration value for Listen-only mode.
#define IbcLON 0x0022 /*Enter listen only mode*/
This parameter is to be used with ibconfig with a board-level unit descriptor. Any non-zero value will enable listen only mode.
Hope this helps.
DiegoF
(3,888 Views)
Yes, that was my first guess. It works fine with a different NI
AT-GPIB controller board, but with the GPIB-ENET all I get is an ECAP
capability error. Can this controller do listen-only?
On Mon, 17 Feb 2003 11:41:34 -0600 (CST), DiegoF wrote:
>Hi,
>mode.
>Hope this helps.
>DiegoF
>National Instruments
(3,888 Views)
You are right. It seems that this controller does not support this feature. I tried the same operation on other interfaces (GPIB-USB and GPIB-ENET/100) and the attribute is set without errors.
DiegoF.
National Instruments.
(3,888 Views)
