How do I stop ENET-232/4 from automatically closing its ports?
I am using an ENET-232/4 to control a development rack remotely. Unfortunately, after leaving a terminal window idle for about a minute, the ENET-232/4 closes the port, forcing me to exit the terminal program and reopen it (disconnecting and reconnecting doesn't suffice). I've tried opening the port through HyperTerminal, Tera Term, and the Measurement & Automation application that NI supplies (MAX). All methods demonstrate the same behavior. I do not see this behavior when I connect directly to the development rack, and the port closing coincides with an ethernet packet from the ENET-232/4.
I'm running Windows XP and NI-Serial version 1.7. The firmware version for the ENET-232/4 is A.1.
Is there a way to prevent the port from timing out?
Glen
(3,972 Views)
Glen,
After reading this thread it looks like this is probably a problem with your ethernet card, or your network settings. I would recommend trying another computer if you have one to see if this is a network issue, and then perhaps another ethernet card.
Shawn B.
Use NI products on Linux? Come join the NI Linux Users Community
(3,944 Views)
Please first download and install the latest version of NI-Serial from the web. If that does not fix the problem, please contact customer support via email for a work around.
Joshua Prewitt
(3,938 Views)
Thanks, Shawn, for the suggestion. It does work from another computer, so maybe the ethernet card is the problem.
Joshua, I mistyped the version number for NI-Serial in my previous post. I'm running 1.71, which I believe is the latest. Sorry for the confusion.
Thanks for the help.
Glen
(3,919 Views)
This has been fixed in NI-Serial 1.8 for Windows. Please download the latest NI-Serial driver if you are having this problem.
Josh Prewitt
(3,756 Views)
