How do i (send to) and (retrieve from) my NI-8451 DAQ device using C#
I am trying to write a program that will interact with my NI-8451 device using C# but I am having problems establishing the interaction.
Message 1 of 19
(5,502 Views)
Hey WHIZ_KID,
Have you seen the 845x Hardware and Software manual? It has pretty detailed descriptions for all the calls needed to interface with the 8451 for both LabVIEW and C. Below is a link to that manual.
http://www.ni.com/pdf/manuals/371746c.pdf
Hope This Helps,
Doug B
Message 2 of 19
(5,492 Views)
Will the funnctions for C work for C#?
Message 3 of 19
(5,481 Views)
Message 4 of 19
(5,477 Views)
Hey guys,
There is not a specific C# API for the 845x driver. Also, I would suspect the C code API won't directly translate to C# as that API is designed for C.
Doug B
Message 5 of 19
(5,467 Views)
I am trying to reference the Ni-845x.dll on my visual studio... but its giving an error... is there anything that can be done?
Message 6 of 19
(5,450 Views)
Hey WHIZ_KID,
If you have Measurement Studio, then you can follow the instructions in this article to program with the 845x driver in C#
http://www.ni.com/white-paper/4562/en
What is the error you are getting when trying to call the 845x dll?
Doug B
Message 7 of 19
(5,443 Views)
Accepted by WHIZ_KID
The error is saying that the dll is not accessible and that it is not a valid assembly or COM component
Message 8 of 19
(5,439 Views)
and also ... for the dll solution, i don't have the plug in of measurement studio for visual studio... it is not working without the plugin... and it i cannot find the site to download the plugin
Message 9 of 19
(5,437 Views)
delete
Message 10 of 19
(5,432 Views)
