How do i set de time range for my VI
how do i set a time range for my VI.  For example, if i were to on my lighting circuit between a time from 6am to 6pm it will sound a alarm. how to set the time range
thanks
regards
jackson
(2,921 Views)
You have a number of functions on the Timing palette as well as the Time Stamp control on the Numeric palette. You can use numeric operations on timestamps (i.e. add/subtract). Try giving them a try and if you run into problems, post back with additional details and attach some example code.
p.s. In the future, you should post similar questions to the LabVIEW board as this has nothing to do with instrument control.
(2,905 Views)
