How to Invert waveform from AFG3101 function generator interfaced using GPIB
I wanted an inverted pulse which can be generated using AFG3101 function generator. But the instrument drivers provided does not have an option INVERT anywhere. So when i went thru the discussion forum, I found solution to write GPIB command "POL:INV". I tried doing this but it flashed an error saying "Unrecognized command". Can anyone please help me in doing this? I want pulse going down from 2.5Vpp to 0 when triggerred.
Sailesh
(4,144 Views)
Hello Sailesh,
       I recommend that you take a look at the instrument drivers that we have available for the AFG3101 and see if the inversion function is implemented in them.  Let us know how if goes.
Cheers,
NathanT
(4,132 Views)
Hello Nathan,
I have downloaded the instrument drivers. But they have not implemented "Inversion" in their VIs. So if i want that feature on labview i need the visa string which does that operation. SO it will be very helpful if you can get me the VISA string.
Sailesh
(4,130 Views)
You might try sending the correct command.Smiley Wink The syntax from the manual is:
OUTPut[1|2]:POLarity{NORMal|INVerted}
You are just sending POL:INV not, for example OUTP1:POL INV
stupid smilies  - correct syntax is OUTP1(colon)POL INV
Message Edited by Dennis Knutson on 08-13-2007 07:50 AM
(4,125 Views)
Thanks Dennis.
Sailesh
(4,106 Views)
