two com port using visa
Dear sir,
Presently i am using visa functions for serial communication using single com port. Now i want a set up just like some instruments will work on com1 and remaining on com2 simultaneously.
 Is it possible? Please suggest me good answer.
(4,023 Views)
just doit.
it works.
greetings from the Netherlands
(4,020 Views)
Hey Falgandha,
I'm not quite sure about your question, but Serial can only communicate to 1 instrument per com port. If you want to communicate to 2 instruments, you could use 2 com ports. A good starting point would be: Open labVIEW->Help->Find Examples->Search "Serial" and you'll find "Basic Serial Write and Read.vi"
Nick D.
(3,995 Views)
i am using here two com ports only. But how can i implement that. Because i want to send the data to two instruments on two com port at the same time.
Please me send vi for that
falgandha
(3,986 Views)
but how can i do that?
please suggest me vi for that
falgandha
(3,986 Views)
They just have to be in parallel. Remember your LabVIEW basics.
Message Edited by Dennis Knutson on 08-13-2007 11:26 PM
(3,982 Views)
