How to access TMPs remotely ?
I want to control Turbo molecular pupms remotely using LabVIW so how can i do it ? I have found its needed drivers from pfeiffer website and installation notes also. So please can any body guide me ? Pupm controller has RS232 connceting port.
(3,673 Views)
You should be able to control and access your Pfeiffer Vacuum products through the serial port(RS232) connection between the pump and your PC.
 Pfeiffer Vacuum products are supported in Labview Instrument Drvier framework
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=9620
Getting started with Instrument Control : https://learn.ni.com/learn/article/getting-started-with-instrument-control-hardware-and-labview
After going through the basics, you may move on a tutorial on how to use instrument control in Labview.
Please access the detailed tutorials and refferences for the Labview instrument driver system.
http://zone.ni.com/devzone/cda/tut/p/id/4376
Trust that helps. All the best.
Ankur
(3,666 Views)
Thanks.....,!
(3,664 Views)
