Serial communication execution
I am relatively new to LabVIEW and I am trying to set up a program using two different RS-232 connections. I have one working correctly (peristaltic pump control), but one is not cooperating (balance measurements). When I run the program, I get a framing error, and when the serial connection is probed, it says it was not executed.
Are there any suggestions as to how to initialize communication?
Message 1 of 9
(5,155 Views)
Did you try a search on framing errors? This is a frequently asked question. Framing errors are generated by the serial port chip in your computer (or whatever external box you're using). These are cause by numerous sources:
  • Incorrect serial port configuration, such as speed, parity, number or bits, etc.
  • Poor connection for cable
  • Noise on the line
  • Bad cable (i.e., frayed lines)
  • Bad instrument
You will need to rule these out one at a time.
Message 2 of 9
(5,153 Views)
Hello msteele,
Thanks for the question!  Can you provide us with more information on the program you're using as well as the error you're seeing?
Additionally, try to use the Basic Serial Write and Read example VI with the "non-cooperating" machine.  You can find this example through Help >> Find Examples.  Then search for serial, and this should be one of the options that come up.
Cheers,
Lisa
Message 3 of 9
(5,136 Views)
Hello msteele,
Cheers,
Lisa
Message 4 of 9
(5,135 Views)
Thanks for the responses.
@smercurio_fc: I had previously searched framing errors, and I don't believe the causes you've listed are the problem I am having. I am able to communicate fine with the instruments through VISA, and even when the program is running, but I am still getting a framing error. From my search, I thought the issue may be a result of not closing the serial ports. I have modified my program (and attached it for reference) to close the serial ports, but I don't think the way I have done it is correct. Should I put the Close command in a new sequence? Or should I change the while loops to have a control rather than a constant 'false'? Would a case loop be more appropriate?
@Lisa J: Again, I have attached my program for reference. There are some notes about the function of each command in various "Description and Tips" boxes. Also, I actually used the Basic Serial Write and Read example VI to setup the program and it was very helpful, but I still get framing errors.
It may also be helpful to know that I don't get the framing error every time I run the program. Generally the first time I run the program when I log on to the computer I don't get the error, which seems to verify that it may be an issue with properly closing the serial ports.
Thanks again,
M. Steele
Message 5 of 9
(5,111 Views)
Not closing a serial port does not generate framing errors. Framing errors are generated by the serial port hardware. They tell you that the byte stream received does not conform to an expected byte stream.
As for your code, you have several issue:
  • Do not configure and close the serial ports inside the loops. This is completely pointless. Open/Configure and close ONCE. This means this operation is done outside of loops.
  • In your second frame you have infinite loops. The only way to stop the loops is to press the ABORT button in the toolbar, or to shut down LabVIEW. THIS IS BAD. You do not need to use multiple loops in this case since your 4 loops can be written to use an event structure. The Timeout case can be used to perform the Pressure indicator update and it can also be used to trigger whatever it is that you're doing with COM4. This can be done by either using a hidden front panel indicator and using the Value (Signaling) property, or you can use a user event.
  • I do not know if you were aware of this, but in the loop in the second frame that has the shift register, that shift register is uninitialized. Thus, the first time the subtraction occurs, the result may not be what you expect.
Message 6 of 9
(5,099 Views)
and within these infinite loops you use COM3 in two loops in parallel.
Message 7 of 9
(5,093 Views)
Thanks for your response.
I am working to correct my program but still having issues. I moved the serial configurations outside of the sequence structure, and tried to combine some of the parallel loops in frame two, but now I am not able to control my instruments as before. Should I have moved serial configuration outside the while loop, but inside the sequence structure?
I think a description of what I am trying to achieve may help you help me. I have three outside devices: (1) a pressure transducer connected through an NI USB-6009 using an analog connection (ai1), (2) a peristaltic pump connected to COM3, and (3) a balance connected through COM4.
I will devide the issues I'm having between instruments:
(1) The pressure transducer is working as I would hope. I would, however, like to write the pressure data to my array file. I am not sure how to convert it to the correct data type.
(2) There are three operations I need to communicate with the pump. In the first frame, I have written and write and read sequence to "identify" the pump (ie. I send it Z1, if it returns Z2, then it has been assigned pump identifier P1). This is executing as needed. In the second frame, I am trying to be able to both set the speed of the pump and be able to turn on and off the pump. That is why I had two parallel while loops using COM3 before. When I tried to combine them into one while loop as suggested, I cannot make both functions operable.
(3) With the balance I want to collect the mass accumulated per time step (3s). I am also hoping to be able to start running the program and control the pump, but tell the program when to start collecting balance data.
I am attaching my program with modifications made, but it does not run as well as the previous version. Any suggestions would be highly appreciated.
Thanks again,
-M. Steele
Message 8 of 9
(5,068 Views)
Have a look at the produce consumer template.
And do put the 3 instruments in parallel loops that produce and consume the data in another loop.
Do not use the same instrument (or port) in more than one loop because you don't know what you are sending from two sides.
Furthermore hide the nitty gritty details of communicating with an instrument in a subvi.
greetings from the Netherlands
Message 9 of 9
(5,064 Views)
