How to acquire graph from hp4155b with labview
I am trying to acquire graph data from the hp/agilent 4155b with labview 7.1. I am using GPIB, and can see and communicate with the instrument using MAX. I am trying to use the getting started.vi from the driver. I give the instrument descriptor "GPIB1::17::INSTR" as it shows in the VISA interactive control.  I receive the error "HP415x Sys-Error Query.vi: +195,"Cal/Diag failed. Cannot use unit." Any idea what is wrong?
(5,360 Views)
That's a message from the instrument returned with the SYST:ERR? query. It's possible that the instrument failed it's internal self-test. Power cycle the instrument and run this query in MAX. The instrument should also support the *TST? command. You can also run this. If the SYST:ERR? or the *TST? queries return the same message, you will have to have the instrument calibrated or repaired by Agilent or a third-party.
(5,357 Views)
Thank you. The getting started.vi is working now. Do you know how to save the graph as image to insert into a Word document? Thank you for your help.
(5,354 Views)
Yes I do know. You can create a reference to the graph and use the Get Image method. The image data can be passed to the Write JPEG File function.
Message Edited by Dennis Knutson on 04-10-2007 09:47 AM
(5,347 Views)
Hi I am also trying to capture real time graph or data from HP4155B. I am using Visa resources.
It only updates the graph at the end of test. Is there any way to update the graph along with test sequence.
Hark
(5,164 Views)
Do you mean that you want to display what is happening during a sweep? If that's so, then probably not. Doing the download trace function would probably interupt the sweep but you can give it a try. The Op-Start-Start function would have to be set to not wait until finished
(5,158 Views)
Yes Dennis, I want to capture it while sweeping. But i think i have to live with what i have now. As i can't put more delay in sweep to read values.
Thanks for your quick response.
(5,138 Views)
