how to read specific bytes in rs232 buffer
Hello Guys
I trying to pull out data from RS232 but i only need to read a specific character. Example :
Read buffers:
level -2.32 locked on
ok*
From that read buffer, all i want to extract is the -2.32. Any ideas? Please give an example.
(3,411 Views)
Use the match string function to search for "level" and then use the scan from string for a float.
Using the scan from string directly probably is too difficult to keep correct.
greetings from the Netherlands
(3,402 Views)
