I have a PXI-8187 Controller with LabVIEW-RT on it. In the same
chassis as that controller I have a PXI-7831R RIO card, and my PXI-5112
Scope. I have made some simple code to create a clock pulse on
one of the DIO lines on the RIO card and it compiles and runs. I
also have a terminal block hooked up the the 7831R and a scope probe on
the proper terminal block connector.
What I would like to do is create some code on my Windows 2000 host,
which calls the NI-SCOPE on the RT System to display what it
sees. Ive tried the calibration example just to see if I
could talk to the scope on my RT system, and I havnt had any such
luck.
Ive tried the following to talk to the Scope:
1) Target "LabVIEW for Windows"
a) Use resource name "visa://192.168.1.2/PXI2::14::INSTR" (this is what
MAX shows the 5112 to be under the Remote System->Devices &
Interfaces)
b) Use resource name "visa://192.168.1.2/PXI2::14"
c) Use resource name "PXI2::14"
2) Target "RT Target 192.168.1.2"
What am I doing wrong, or is this not possible/feasable?
Thank you,
-Sean
