How to communicate with my PXI-5112 Scope on a Real-Time System?
I have a PXI-8187 Controller with LabVIEW-RT on it.  In the same chassis as that controller I have a PXI-7831R RIO card, and my PXI-5112 Scope.  I have made some simple code to create a clock pulse on one of the DIO lines on the RIO card and it compiles and runs.  I also have a terminal block hooked up the the 7831R and a scope probe on the proper terminal block connector.
What I would like to do is create some code on my Windows 2000 host, which calls the NI-SCOPE on the RT System to display what it sees.   Ive tried the calibration example just to see if I could talk to the scope on my RT system, and I havnt had any such luck.
Ive tried the following to talk to the Scope:
1) Target "LabVIEW for Windows"
a) Use resource name "visa://192.168.1.2/PXI2::14::INSTR" (this is what MAX shows the 5112 to be under the Remote System->Devices & Interfaces)
b) Use resource name "visa://192.168.1.2/PXI2::14"
c) Use resource name "PXI2::14"
2) Target "RT Target 192.168.1.2"
What am I doing wrong, or is this not possible/feasable?
Thank you,
-Sean
(3,304 Views)
PXI-5112 is not officially supported in LabVIEW RT. Having said that, it does work at times.
But I would still recommend you to try it out with the resourse name as DAQ::14 or PXI2Slot14. Of course you give it an alias too.
Hope this helps if not please repost.
Arun V
(3,279 Views)
