How to conect WIKA DI35 digital indicator via RS 485 on PXI-8431?
HI
Can anyone tell me, how to connect WIKA DI35 digital indicator with RS 485 on PXI 8431 board. Terminals on indicator are marked as GND (RS), B(+) and A(-) so how to connect this terminals on pins in DB-9 connector? Maybe anyone knows where to find an example or driver for this indicator? I’m using LV 7.1. Thanx for any help.
Regards, Topko
(4,097 Views)
Hi Topko,
Here is an Knowledge Base that shows the pin out of our DB9 Connector. GND will need to be connected to pin 5 but you will have to determine what B(+) and A(-) actually are based on your devices manual. I looked on ni.com/idnet  but I could not find an instrument driver for your DI35 device. You might check with the manufacturer to see if they provide a LabVIEW driver.
Regards
Krista S.
Applications Engineering
(4,076 Views)
In manuals for this indicator - there where no useful information about connection on RS 485 (you can look yourselves on their homepage that particularly manuals). I tried all possible connection combinations with no response from indicator. Now, when I reed other problems with communications, I will try with different terminate characters in any possible connection. Results will be announced in this forum as soon as I perform tests on all of combinations. I'm sorry, that  I don't have any other instrument with RS485 communication to test, so I can't be sure, if this DI35 RS 485 communication is working properly.
regards, Topko
(4,076 Views)
Since you did not provide a link, I did a google search and found http://www.wika.de/pdf/betriebsanleitungen/englisch/ba_di35_d.pdf near the top of the results. On page 6, there are instructions for an RS-485 connection and section 6 describes how you can use a program such as hyperterminal to communicate. I would recomend you try that first before trying to code anything yourself.
(4,066 Views)
As you can see, there are data lines marked as A(-) and B(+) in this manuals. Do you have any sugestion on which pin in DB9 connector (TXD-, TXD+, RXD- and RXD+) this data lines have to be connected?
(4,060 Views)
I'm a little rusty with RS-485 but I think this is intended to operate in half-duplex mode. Connect to the TXD+ and TXD- lines.
(4,050 Views)
