How to connect QL355TP Power Supply
Hi Graeme Smith,
Were you successfully automated QL355TP? I'm trying with Python & LabView. No success so far. Could you please share your knowledge how you brought it up?
Satheesh
Message 21 of 26
(1,701 Views)
Hello, I have the same error, I can send commands and I managed to set voltages, or voltage steps, etc. but I can't read the data backwards as with the * IDN command ?. Said to make a driver work, but I don't know how.
Message 22 of 26
(1,643 Views)
I have made it work. You need to give enough delay for the data t be available on the UART. Will share my code on Monday.
Satheesh
Message 23 of 26
(1,625 Views)
Hi! I had a error conection with internet this morning but I had read you, if u can, send the code pls.
Message 24 of 26
(1,614 Views)
I have given 20ms delay to read the data.
serialPort_PSU.WriteLine("*IDN?");
Thread.Sleep(20);
PSU_receiveBuffer = PSU_receiveBuffer + serialPort_PSU.ReadExisting();
You can refer to the attached file for complete code. It's written in C#
Satheesh
Message 25 of 26
(1,608 Views)
Ok thanks! I think I can implement this code on Pyvisa but Im new in labview, do u said that can I implement this code on labview?
Message 26 of 26
(1,605 Views)
